Текущее время: 05 ноя 2026, 15:22
 Заголовок сообщения: Не работает CO Ring Assignment(167) [N]
Непрочитанное сообщениеДобавлено: 08 авг 2017, 18:43
И так ...
Имеем 3 аккаунта/номера SIP с 10 линиями на каждом.
Имеем 3 группы SIP CO (7,8,9) привязанные к аккаунтам.
PGM 160
49 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
50 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
51 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
52 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
53 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
54 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
55 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
56 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
57 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
58 VOIP/SIP Normal 7 7 1 7 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
59 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
60 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
61 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
62 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
63 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
64 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
65 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
66 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
67 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
68 VOIP/SIP Normal 8 8 1 8 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
69 VOIP/SIP Normal 9 9 1 9 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
70 VOIP/SIP Normal 9 9 1 9 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
71 VOIP/SIP Normal 9 9 1 9 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
72 VOIP/SIP Normal 9 9 1 9 DTMF All Call NONE SIP 50 0 1 1 1 0 Enblock On
PGM 167
49 Feature 0 670001 Feature 0 670002 Ring Assign 0
50 Feature 0 670001 Feature 0 670002 Ring Assign 0
51 Feature 0 670001 Feature 0 670002 Ring Assign 0
52 Feature 0 670001 Feature 0 670002 Ring Assign 0
53 Feature 0 670001 Feature 0 670002 Ring Assign 0
54 Feature 0 670001 Feature 0 670002 Ring Assign 0
55 Feature 0 670001 Feature 0 670002 Ring Assign 0
56 Feature 0 670001 Feature 0 670002 Ring Assign 0
57 Feature 0 670001 Feature 0 670002 Ring Assign 0
58 Feature 0 670001 Feature 0 670002 Ring Assign 0
59 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
60 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
61 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
62 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
63 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
64 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
65 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
66 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
67 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
68 Ring Assign [273:0] 0 Ring Assign [273:0] 0 Ring Assign 0
69 Feature 0 670001 Feature 0 670002 Ring Assign 0
70 Feature 0 670001 Feature 0 670002 Ring Assign 0
71 Feature 0 670001 Feature 0 670002 Ring Assign 0
72 Feature 0 670001 Feature 0 670002 Ring Assign 0
При звонке на второй аккаунт (8 группа) попадаю на первый (7 группа), т.е. не на 273 номер, а на робобабу. Причем PGM 101 показывает, что активируется SIP CO из 7 группы
Перечитал всё. Не работает так как надо и понять не могу, почему.
Коллеги, есть мысли?
 Заголовок сообщения: Re: Не работает CO Ring Assignment(167) [N]
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:08
У вас три аккаунта, но провайдер один, как я понял. В таком случае, вы по исходящей можете разделить линии по аккаунтам, определив их в разные Outgoing CO Group, что у вас и сделано. А вот входящие могут поступить по любой линии, относящейся к провайдеру.
Т.е., линии при входящей в вашем варианте по аккаунтам разбить нельзя, но вызовы по-разному назначить можно! Надо в 160 использовать не Normal, а DID. И вызовы входящие назначать в Digit Conv Table.
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:21
И даже разные аккаунты не помогают? 8-о
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:29
Не помогают в чем?
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:35
В разделении входящих звонков на группы.
Соответственно 8 - 8 и 9 - 9 в красном кружке.
33.jpg [ 253.55 KiB | Просмотров: 6320 ]
3.jpg [ 526.91 KiB | Просмотров: 6320 ]
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:50
Я ж написал. На группы не разбить, но вызовы по-разному для разных аккаунтов назначить можно!
Да, тема некорректно названа, ибо CO Ring Assignment(167) работает так, как и должна работать в вашем варианте. :-)
Непрочитанное сообщениеДобавлено: 08 авг 2017, 19:55
Ваша хотелка тут обсуждалась уже и достаточно основательно. Давненько, правда. Но, поиск же по форуму имеется...
Непрочитанное сообщениеДобавлено: 09 авг 2017, 03:13
А если бы провайдер был не один и тот же? Работало бы?
Вообще, логика софта этой станции, иногда, ставит в тупик. Почему, если я указываю конкретный номер аккаунта, на конкретную CO Gr, соединение уходит куда-то ещё? Ерунда какая-то.
Ладно, пойду курить (крутить) DID вместо нормала. Там, наверняка, свои приколы попрут. :-\
Непрочитанное сообщениеДобавлено: 09 авг 2017, 07:25
Работало бы.
Просто корейцы не понимают, зачем разбивать линии одного провайдера по аккаунтам. Это, вообще то, логика аналоговых линий - каждая линия является отдельным конкретным номером.
Они, например, не понимают, зачем подключать несколько сип провайдеров. Уних, видимо, нет большой разницы по тарифам на разные направления у разных провайдеров.
В общем то, линейка станций MG больше не развивается. А жаль, во многом идеология этой станции мне очень даже нравится. Потомок eMG800. Все железо от MG, но с новым процессором.
Корейцы пошли по пути унификации софта. За основу взят софт станций LIK.
