Текущее время: 10 май 2026, 19:58
Начать новую тему Ответить на тему  [ Сообщений: 34 ]  На страницу Пред.  1, 2, 3, 4
Непрочитанное сообщениеДобавлено: 26 фев 2025, 08:10
Прогрузка платы
Цитата:
ARMboot Bz17934_1 lge NORFLASHBOOT (Aug 22 2011 - 15:01:41)
ARMboot code: 03f00000 -> 03f410f4
NAND CHIP : 0
NAND MID:0xec, Chip ID:0xf1 (Samsung NAND 128MB 3,3V)
NAND CHIP : 1
Comcerto info:
CPU: M828xx
EVM: MPB100
SDC Version: 0x560e
SDC Device ID: 0x130
Bounding option: 0xecc9
CFG HZ: 132000000
NAND MSP start: 1
NAND MSP size: 31
NAND CSP start: 0
NAND CSP size: 0
NOR Base addr: 0x11000000
EPROM Base addr: 0x00000000
DRAM Configuration:
Bank #0: 00800000 56 MB
Bank #1: 04000000 47 MB
*** sdram start 0x00800000
*** sdram size 0x03800000
*** 2nd sdram start 0x04000000
*** 2nd sdram size 0x02f00000
*** boot param addr 0x00800100
Hit Ctrl-C key to stop autoboot: 0
Start DeMerge Kernel
DeMerge:: unzip MSP success [size is 1948976]
DeMerge:: CSP size is 1613000 [112f1a05 >> 00f89cc8]
DeMerge Success (MSP) at 0x01000000, (CSP) at 0x00E00000 ...
Downloading MSP Image from 0x1000000 ...
code_offset=0x80
code_base=8000
data_offset=cd3d0
code_size=cd350
data_base=d5350
data_size=ec418
zeroinit_base=1c1768
prog_entry=100
AIFHEADER:
BL_DecompressCode=e1a00000
BL_SelfRelocCode=e1a00000
BL_DbgInitZeroInit=eb00000c
EntryPointOffset=ffff8100
ProgramExitInstr=ef000011
ImageReadOnlySize=cd350
ImageReadWriteSize=ec418
ImageDebugSize=1e0fc
ImageZeroInitSize=dd64
ImageDebugType=1df041
ImageBase=8000
WorkSpace=0
AddressMode=20
DataBase=0
FirstFatOffset=1d78e4
Reserved2=0
DebugInitInstr=e1a00000
ZeroInitCode[0]=e04ec00f
Booting ARM0 (CSP) at 0x00E00000 ...
Booting ARM1 (MSP) at 0x00000100 ...
Linux version 2.6.11.7-1.07.0malindi (chows@ipecsmg.lgericsson.com) (gcc version
3.3.2 20030820 (prerelease)) #180 Mon Aug 22 10:59:58 KST 2011
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: ARM-M828xx Comcerto
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock1 rw ip=10.10.10.1:1
0.10.10.10:10.10.10.254:255.255.255.0::eth0
PID hash table entries: 512 (order: 9, 8192 bytes)
timer1 enable#########
timer2 disable $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
timer3 disable $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 56MB 47MB = 103MB total
Memory: 100864KB available (2557K code, 637K data, 308K init)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Comcerto GPIO: init
Comcerto GPIO: GPIOs 0 configured as IRQ source(s)
Comcerto PCI: init
Comcerto PCI: Comcerto device is not configured in PCI host
Verify that HBMODE_n(low) pin is high and HBBURSTEN_n(high) pin is low
On Mindspeed MH02-D370-xxx board, remove jumper JPCISLV1
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
SPI core: loaded version 0.2
NetWinder Floating Point Emulator V0.97 (double precision)
NTFS driver 2.1.22 [Flags: R/W DEBUG].
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Aug 20 2011 11:46:08 Installing.
Initializing Cryptographic API
Crypto engine S/W registered
Serial: 8250/16550 driver $Revision: 1.1.1.3 $ 2 ports, IRQ sharing disabled
Serial: Comcerto 16550 serial driver $Revision: 1.4 $
ttyS0 at MMIO 0x10090000 (irq = 41) is a 16550A
ttyS1 at MMIO 0x10094000 (irq = 58) is a 16550A
io scheduler noop registered
loop: loaded (max 8 devices)
nbd: registered device at major 43
skb pool filled with 512 skb
m828xx_msp_start()
stop EMAC0 control
stop_emac0: already stopped
m828xx_msp_ready()
MSP version : $Version: m828_v2_06_6 $
msp_ready: MSP is running
switch eth0 to VED mode
smi_memory_phy = 6f0000
SharedMemoryRxControlStructure(PA): 0x800023c
SharedMemoryRxControlStructure(VA): 0xf800023c
SharedMemoryTxControlStructure(PA): 0x800023c
SharedMemoryTxControlStructure(VA): 0xf800023c
drivers/net/comcerto_ved.c: 1630: SetupSMIBuffers: 1280 buffers allocated
Comcerto SMI: fpq(PA): 0x8001350
Comcerto SMI: fpq(VA): 0xf8001350
Comcerto SMI: fpq(PA): 0x8001370
Comcerto SMI: fpq(VA): 0xf8001370
Comcerto SMI: fpq(PA): 0x800021c
Comcerto SMI: fpq(VA): 0xf800021c
Comcerto SMI: fpq(PA): 0x800022c
Comcerto SMI: fpq(VA): 0xf800022c
Comcerto SMI: fpq(PA): 0x8001360
Comcerto SMI: fpq(VA): 0xf8001360
Comcerto SMI: fpq(PA): 0x8001380
Comcerto SMI: fpq(VA): 0xf8001380
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
mtd: NAND opt=c0779e34, ale-cycles=4, blk(rd=16, wr=16), ce=1, tR=0
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bi
t)
Scanning device for bad blocks
Bad eraseblock 228 at 0x01c80000
Bad eraseblock 270 at 0x021c0000
Creating 2 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00400000 : "NAND#0 Kernel partition"
0x00400000-0x08000000 : "NAND#0 Comcerto Filesystem partition"
mtd: NAND opt=c0779a34, ale-cycles=4, blk(rd=16, wr=16), ce=2, tR=0
t)
Bad eraseblock 9 at 0x00120000
Bad eraseblock 49 at 0x00620000
Bad eraseblock 840 at 0x06900000
Bad eraseblock 986 at 0x07b40000
Creating 3 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x01800000 : "NAND#1 prompt message partition"
0x01800000-0x02800000 : "NAND#1 system announcement partition"
0x02800000-0x08000000 : "NAND#1 all nation prompt rom partition"
m828xx-ohci m828xx-ohci: at 0xd00e0400, irq 13
m828xx-ohci m828xx-ohci: new USB bus registered, assigned bus number 1
usb usb1: Product: M828xx OHCI
usb usb1: Manufacturer: Linux 2.6.11.7-1.07.0malindi ohci_hcd
usb usb1: SerialNumber: m828xx-ohci
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
USB Universal Host Controller Interface driver v2.2
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
SPI core: add adapter comcerto-spi
ISDN subsystem Rev: 1.1.1.3/1.1.1.2/1.1.1.2/1.1.1.3/none/1.1.1.1
isdnloop-ISDN-driver Rev 1.1.1.2
Register LDKPPP Device Driver.
isdnloop: (loop0) virtual card added
Crypto engine MSPD IPsec2 registered
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
IPv4 over IPv4 tunneling driver
Initializing IPsec netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
IP-Config: Complete:
device=eth0, addr=10.10.10.1, mask=255.255.255.0, gw=10.10.10.254,
host=10.10.10.1, domain=, nis-domain=(none),
bootserver=10.10.10.10, rootserver=10.10.10.10, rootpath=
yaffs: dev is 32505857 name is "mtdblock1"
yaffs: Attempting MTD mount on 31.1, "mtdblock1"
yaffs: MTD device does not support have the right page sizes
block 197 is bad ,so Try to clean!!
Clean block 197 Fail!!
block 239 is bad ,so Try to clean!!
Clean block 239 Fail!!
VFS: Mounted root (yaffs2 filesystem).
Freeing init memory: 308K
init started: BusyBox v1.01 (2006.02.06-07:50+0000) multi-call binary
Starting pid 17, console /dev/console: '/etc/rc'
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
block 10 is bad ,so Try to clean!!
Clean block 10 Fail!!
block 50 is bad ,so Try to clean!!
Clean block 50 Fail!!
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
yaffs: dev is 32505860 name is "mtdblock4"
yaffs: Attempting MTD mount on 31.4, "mtdblock4"
block 521 is bad ,so Try to clean!!
Clean block 521 Fail!!
block 667 is bad ,so Try to clean!!
Clean block 667 Fail!!
Thu Jan 1 12:00:00 UTC 2009
kernel.msgmni = 100
kernel.msgmnb = 65536
net.ipv4.tcp_keepalive_time = 60
net.ipv4.ip_nonlocal_bind = 1
tar: /execute.tar: No such file or directory
rm: cannot remove `/execute.tar': No such file or directory
NET: Registered protocol family 27
REGISTER devGpio device 0.1.1 OK
REGISTER devMisc device 0.1.1 OK
sram: hd_sect=512, nsect=8192
sram: major number = 254
sram: installed, system=MG-MPB100(issue=1), va=c6900000, rev=3.0.0.5
--- fs_init: check file system(boot_record=56)...
--- fs_init: finished, virtual volume=8.0MB
sram: wrapper, remap wrapper base, phy=6f00000, size=1100000, map=c6d80000
sram: --- w_s=1100000, wd=100000(8000)
sram: wrapper, fixed t=32768, r=2048...
sram: wrapper, init., wrp_cnt=0, wrp_wr=0
sram: wrapper, pid=38, set_name=kthread_sram_wrapper
sram: wrapper, init. ended(2048/0/0), max_off=0
:: sram wrapper kthread, entry, dev=bf01698c
REGISTER devAct2 device 0.1.1 OK
devBootEnv:installed(1.Ba, rmii) - sect(mac:0x3f0000, env:0x3f2000, env_back:0x3
f4000)
eeee 0
REGISTER devSlot device 0.1.1 OK
REGISTER devMoh device 0.1.1 OK
LAN Switch & PHY Reset... OK
REGISTER devSEEPROM device 0.1.1 OK
REGISTER devTwl device 0.1.1 OK
REGISTER devLco device 0.1.4 OK
REGISTER devTimer device 0.1.1 OK
--- k_pid=49
:: kernel thread, entry
devNetc:installed (crypto info: name=MSPD IPsec2, capability=null|md5|sha1|sha25
6|des|3des|aes)
revision:2.0Bm, woori-bank paging
======== EMAC_ARCCTRL=00000014
voimmisc:installed
REGISTER device SPI OK
spi_io_base : d0098000
ippp0 added
Encapsulation for ippp0 is syncppp
EAZ/MSN for ippp0 is 100
Layer-2-Protocol for ippp0 is hdlc
Hangup-Timeout for ippp0 is 180 sec.
dhcpContinue stop
DHCP wait 3 sec
DHCP Loop End
[iPECS Loader] Apploader Start
[iPECS Loader] Loading the Loader File
[iPECS Loader] Autoloader Execute /home/_main_app1.rom from the loader file
[HtmlExtractProcess]extract start.
[GS55H21Ac.rom] Html V File Extract Success![776]
[HtmlExtractProcess]extract end
Thu Jan 8 22:55:00 UTC 2009
[SYSLOG ][09/01/08 22:55:49]
[SYSLOG ][09/01/08 22:55:49] ===== START iPECS-MG_SYSTEM =====
[SYSLOG ][09/01/08 22:55:49] Version : iPECS-MG 55M-2.1Ac
[SYSLOG ][09/01/08 22:55:49] Release Date : DEC/12
[SYSLOG ][09/01/08 22:55:49] Working Dir : /
[SYSLOG ][09/01/08 22:55:49] Process ID : (PID 77)
[SYSLOG ][09/01/08 22:55:49] New DB Type Indexing for System Init !!
- wrap_unavail: inactivate...
:: sram wrapper kthread, by exit
- wrap_unavail: end...
[SYSLOG ][09/01/08 22:55:49] First Main Act2 Init-Complete Ver(1.1)
devSpi Open
kill: 1: Illegal number: dhcpcd
[SYSLOG ][09/01/08 22:55:49] [NET_INIT] Ethernet IP : 10.10.10.1
**** MindSpeed h/w platform, id -> 12, Max Call --> 8 ****
VAINIT : dev(ipfilter), ver=2.0Bm, woori-bank paging
### ======================== DSP's Info. =============================== ###
ST 1 : query about dev_version : rev. B
ST 2 : query about msp armcode_version : m828_v2_06_6
ST 3 : query about msp spucode_version : C64V_5_12_39
ST 4 : spucode_version verification : passed!
ST 5 : initialize remain dsp parts...
ST 6 : end of dsp init.
[SYSLOG ][09/01/08 22:55:49] Dsp Version : 1.1(10/03/16)
done
[SYSLOG ][09/01/08 22:55:49] Boot Version : 1.1Ab AUG/11
[SYSLOG ][09/01/08 22:55:49] OS Version : 1.1Ab AUG/11
[SYSLOG ][09/01/08 22:55:49] Comp - 2012/12/21 16:46:20
isdnloop: (loop0) DRV1.23EC-Q.931-CAPI-CNS-BASIS-20.02.96
isdnloop: (loop0) Euro-Protocol loaded and running
ifInet6 is NULL...
Snmp agent thread started pid = 118
[OAM ][SNMP ] Save DB to File : SNMP is Disabled
iPECS-MG MPB100 System
Version iPECS-MG/DX55M-2.1Ac DEC/12
Checksum: 0
Dsp Version: 1.1(10/03/16),(A-law)
DATE: 01/08/09
TIME: 22:57:38
SITE NAME:
You are on STDIN
ENTER PASSWORD:
Непрочитанное сообщениеДобавлено: 26 фев 2025, 08:53
В общем и целом, как выше писал, АТС жива. Есть некие проблемы с памятью - присутствуют битые сектора. Вероятно, требуется провести процедуру Recovery. Но. для начала, попробуйте логи почистить...
пароль brandy
maint>log clear
maint> slog clear
Непрочитанное сообщениеДобавлено: 06 мар 2025, 10:01
пароль brandy
maint>log clear
maint> slog clear
Добрый день.
Выполнил очистку - всё по-старому.
Подскажите, как выполнить процедуру Recovery?
Может через HiperTerminal сетевые реквизиты прописать, с которыми он раньше работал? Или, если нет в данный момент подключение через Web, не поможет в решение доступности под прописку?
Непрочитанное сообщениеДобавлено: 10 апр 2025, 04:40
Получилось подключиться к АТС по Web. Поставили чистую XP+IE - подключился без проблем. До этого пробовали и на XP, и на Win7
Спасибо за советы.
