| SIP General Pool is overflow http://atsvtule.ru/forum/viewtopic.php?f=5&t=1338 |
Страница 1 из 2 |
| Автор: | turbo [ 16 дек 2013, 15:35 ] |
| Заголовок сообщения: | SIP General Pool is overflow |
Добрый день! Появилась в System Log во такая штука: SIP General Pool is overflow!!! [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] SIP STACK STATUS(v5.5.0.13) [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] MODULE RESOURCE Current Usage Max Usage Allocated [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] Stack General Pool 4 320 320 [13/12/16 15:24:45] Message Pool 0 160 160 [13/12/16 15:24:45] Header Pool 0 6 756 [13/12/16 15:24:45] Timer Pool 0 159 840 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Call Legs Calls 0 3 140 [13/12/16 15:24:45] transcHandles 0 2 222 [13/12/16 15:24:45] transcLists 0 3 140 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Transactions Transactions 0 159 222 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Reg Clients Reg Clients 0 2 80 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Transport connections 2 2 80 [13/12/16 15:24:45] connHash 0 0 80 [13/12/16 15:24:45] ownersHash 0 0 1552 [13/12/16 15:24:45] pQueueElements 0 106 534 [13/12/16 15:24:45] pQueueEvents 0 107 534 [13/12/16 15:24:45] readBuffers 0 10 267 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Subs subscriptions 0 0 60 [13/12/16 15:24:45] notifications 0 0 300 [13/12/16 15:24:45] notifyLists 0 0 60 [13/12/16 15:24:45] transcHandles 0 0 60 [13/12/16 15:24:45] ================================================================================ Пишет в логи каждые 2 секунды и забивает память. Я думал это что-то извне - отрубил АТС от внешнего мира - тоже самое в логе. Линии на VOIB4 (встроенном) работают нормально, и входящие и исходящие. АТС IPECS-MG MPB-100 iPECS-MG/GS55MxB.1Bt OCT/13 Boot Version-1.1Ab AUG/11 OS Version-1.1Ab AUG/11 Пробовал найти в инете что-то подобное, ничего не нашел. В каком направлении хоть копать? И небольшой вопрос не в тему - можно ли перепрошивкой центрального блока физически повредить микросхемы памяти, так чтобы их пришлось заменять? |
| Автор: | Dron [ 16 дек 2013, 18:23 ] |
| Заголовок сообщения: | Re: SIP General Pool is overflow |
turbo писал(а): Добрый день! Появилась в System Log во такая штука: SIP General Pool is overflow!!! [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] SIP STACK STATUS(v5.5.0.13) [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] MODULE RESOURCE Current Usage Max Usage Allocated [13/12/16 15:24:45] ================================================================================ [13/12/16 15:24:45] Stack General Pool 4 320 320 [13/12/16 15:24:45] Message Pool 0 160 160 [13/12/16 15:24:45] Header Pool 0 6 756 [13/12/16 15:24:45] Timer Pool 0 159 840 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Call Legs Calls 0 3 140 [13/12/16 15:24:45] transcHandles 0 2 222 [13/12/16 15:24:45] transcLists 0 3 140 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Transactions Transactions 0 159 222 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Reg Clients Reg Clients 0 2 80 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Transport connections 2 2 80 [13/12/16 15:24:45] connHash 0 0 80 [13/12/16 15:24:45] ownersHash 0 0 1552 [13/12/16 15:24:45] pQueueElements 0 106 534 [13/12/16 15:24:45] pQueueEvents 0 107 534 [13/12/16 15:24:45] readBuffers 0 10 267 [13/12/16 15:24:45] -------------------------------------------------------------------------------- [13/12/16 15:24:45] Subs subscriptions 0 0 60 [13/12/16 15:24:45] notifications 0 0 300 [13/12/16 15:24:45] notifyLists 0 0 60 [13/12/16 15:24:45] transcHandles 0 0 60 [13/12/16 15:24:45] ================================================================================ С таким не сталкивался. Даже и не знаю, что сказать. Случайно, трассировка SIP не запущена? Ну, это как предположение. |
| Автор: | Dron [ 16 дек 2013, 18:27 ] |
turbo писал(а): можно ли перепрошивкой центрального блока физически повредить микросхемы памяти, так чтобы их пришлось заменять? Физически, типа, сжечь? Вряд ли, а вот повредить капитально на программном уровне, так сказать, можно. Например, во время записи в память из буфера вдруг пропадет питание, или перезагрузить АТС... |
| Автор: | turbo [ 16 дек 2013, 18:42 ] |
Нет трассировка SIP не запускалась, вже ж работает. Я вот тоже ума не приложу что это. |
| Автор: | Dron [ 16 дек 2013, 18:51 ] |
Я переслал наверх, может чего скажут. Нет никакой документации по логам - что, когда, почему. |
| Автор: | turbo [ 16 дек 2013, 18:54 ] |
Dron писал(а): Я переслал наверх, может чего скажут. Нет никакой документации по логам - что, когда, почему. Спасибо большое. Будем ждать. |
| Автор: | turbo [ 14 янв 2014, 19:49 ] |
Добрый день! Не было никакой информации по проблеме? |
| Автор: | Dron [ 15 янв 2014, 08:24 ] |
Пока нет. Я сегодня еще раз поднял этот вопрос. Вы почаще появляйтесь и напоминайте. Я ж один не могу все помнить. Одно дело свои проблемы, другое дело чужие.
| Автор: | Dron [ 15 янв 2014, 08:36 ] |
Еще уточните, пожалуйста, память забивается, а все остальное то как, работает? Или, по другому, чем все это заканчивается? Что в итоге... |
| Автор: | turbo [ 15 янв 2014, 10:16 ] |
Когда забивается память, то самое первое что бросается в глаза когда лазишь по админке - начитают страницы выводится с ошибками, а некоторые вообще не отображаются. После очистки логов через telnet веб админка поднимается. |
