Текущее время: 24 окт 2026, 10:34
 Заголовок сообщения: ipecs-mg 100
Непрочитанное сообщениеДобавлено: 11 апр 2017, 09:36
Добрый день, Столкнулся с данной АТС ipecs-mg 100 впервые.
Есть проблемы при загрузке
Код:
ARMboot Bz17934_1 lge NORFLASHBOOT  (Aug 22 2011 - 15:01:41)
ARMboot code: 03f00000 -> 03f410f4
NAND CHIP : 0
NAND MID:0xec, Chip ID:0xf1 (Samsung NAND 128MB 3,3V)
NAND CHIP : 1
Comcerto info:
  CPU:             M828xx
  EVM:             MPB100
  SDC Version:     0x560e
  SDC Device ID:   0x130
  Bounding option: 0xecc9
CFG HZ:            132000000
NAND MSP start:    1
NAND MSP size:     31
NAND CSP start:    0
NAND CSP size:     0
NOR Base addr:     0x11000000
EPROM Base addr:   0x00000000
DRAM Configuration:
Bank #0: 00800000 56 MB
Bank #1: 04000000 47 MB
*** sdram start     0x00800000
*** sdram size      0x03800000
*** 2nd sdram start     0x04000000
*** 2nd sdram size      0x02f00000
*** boot param addr 0x00800100
Hit Ctrl-C key to stop autoboot:  0
Start DeMerge Kernel
DeMerge:: unzip MSP success [size is 1948976]
DeMerge:: CSP size is 1613000 [112f1a05 >> 00f89cc8]
DeMerge Success (MSP) at 0x01000000, (CSP) at 0x00E00000 ...
Downloading MSP Image from 0x1000000 ...
code_offset=0x80
code_base=8000
data_offset=cd3d0
code_size=cd350
data_base=d5350
data_size=ec418
zeroinit_base=1c1768
prog_entry=100
AIFHEADER:
BL_DecompressCode=e1a00000
BL_SelfRelocCode=e1a00000
BL_DbgInitZeroInit=eb00000c
EntryPointOffset=ffff8100
ProgramExitInstr=ef000011
ImageReadOnlySize=cd350
ImageReadWriteSize=ec418
ImageDebugSize=1e0fc
ImageZeroInitSize=dd64
ImageDebugType=1df041
ImageBase=8000
WorkSpace=0
AddressMode=20
DataBase=0
FirstFatOffset=1d78e4
Reserved2=0
DebugInitInstr=e1a00000
ZeroInitCode[0]=e04ec00f
Booting ARM0 (CSP) at 0x00E00000 ...
Booting ARM1 (MSP) at 0x00000100 ...
Linux version 2.6.11.7-1.07.0malindi (chows@ipecsmg.lgericsson.com) (gcc version 3.3.2 20030820 (prerelease)) #180 Mon Aug 22 10:59:58 KST 2011
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Machine: ARM-M828xx Comcerto
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock1 rw ip=10.10.10.1:10.10.10.10:10.10.10.254:255.255.255.0::eth0
PID hash table entries: 512 (order: 9, 8192 bytes)
timer1 enable#########
timer2 disable $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
timer3 disable $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 56MB 47MB = 103MB total
Memory: 100864KB available (2557K code, 637K data, 308K init)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Comcerto GPIO: init
Comcerto GPIO: GPIOs 0 configured as IRQ source(s)
Comcerto PCI: init
Comcerto PCI: Comcerto device is not configured in PCI host
        Verify that HBMODE_n(low) pin is high and HBBURSTEN_n(high) pin is low
        On Mindspeed MH02-D370-xxx board, remove jumper JPCISLV1
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
SPI core: loaded version 0.2
NetWinder Floating Point Emulator V0.97 (double precision)
NTFS driver 2.1.22 [Flags: R/W DEBUG].
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Aug 20 2011 11:46:08 Installing.
Initializing Cryptographic API
Crypto engine S/W registered
Serial: 8250/16550 driver $Revision: 1.1.1.3 $ 2 ports, IRQ sharing disabled
Serial: Comcerto 16550 serial driver $Revision: 1.4 $
ttyS0 at MMIO 0x10090000 (irq = 41) is a 16550A
ttyS1 at MMIO 0x10094000 (irq = 58) is a 16550A
io scheduler noop registered
loop: loaded (max 8 devices)
nbd: registered device at major 43
skb pool filled with 512 skb
m828xx_msp_start()
stop EMAC0 control
stop_emac0: already stopped
m828xx_msp_ready()
MSP version : $Version: m828_v2_06_6 $
msp_ready: MSP is running
switch eth0 to VED mode
smi_memory_phy = 6f0000
SharedMemoryRxControlStructure(PA): 0x800023c
SharedMemoryRxControlStructure(VA): 0xf800023c
SharedMemoryTxControlStructure(PA): 0x800023c
SharedMemoryTxControlStructure(VA): 0xf800023c
drivers/net/comcerto_ved.c: 1630: SetupSMIBuffers: 1280 buffers allocated
Comcerto SMI: fpq(PA): 0x8001350
Comcerto SMI: fpq(VA): 0xf8001350
Comcerto SMI: fpq(PA): 0x8001370
Comcerto SMI: fpq(VA): 0xf8001370
Comcerto SMI: fpq(PA): 0x800021c
Comcerto SMI: fpq(VA): 0xf800021c
Comcerto SMI: fpq(PA): 0x800022c
Comcerto SMI: fpq(VA): 0xf800022c
Comcerto SMI: fpq(PA): 0x8001360
Comcerto SMI: fpq(VA): 0xf8001360
Comcerto SMI: fpq(PA): 0x8001380
Comcerto SMI: fpq(VA): 0xf8001380
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
mtd: NAND opt=c0779e34, ale-cycles=4, blk(rd=16, wr=16), ce=1, tR=0
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 682 at 0x05540000
Bad eraseblock 975 at 0x079e0000
Creating 2 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00400000 : "NAND#0 Kernel partition"
0x00400000-0x08000000 : "NAND#0 Comcerto Filesystem partition"
mtd: NAND opt=c0779a34, ale-cycles=4, blk(rd=16, wr=16), ce=2, tR=0
Bad eraseblock 477 at 0x03ba0000
Bad eraseblock 480 at 0x03c00000
Creating 3 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x01800000 : "NAND#1 prompt message partition"
0x01800000-0x02800000 : "NAND#1 system announcement partition"
0x02800000-0x08000000 : "NAND#1 all nation prompt rom partition"
m828xx-ohci m828xx-ohci: at 0xd00e0400, irq 13
m828xx-ohci m828xx-ohci: new USB bus registered, assigned bus number 1
usb usb1: Product: M828xx OHCI
usb usb1: Manufacturer: Linux 2.6.11.7-1.07.0malindi ohci_hcd
usb usb1: SerialNumber: m828xx-ohci
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
USB Universal Host Controller Interface driver v2.2
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
SPI core: add adapter comcerto-spi
ISDN subsystem Rev: 1.1.1.3/1.1.1.2/1.1.1.2/1.1.1.3/none/1.1.1.1
isdnloop-ISDN-driver Rev 1.1.1.2
Register LDKPPP Device Driver.
isdnloop: (loop0) virtual card added
Crypto engine MSPD IPsec2 registered
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
IPv4 over IPv4 tunneling driver
Initializing IPsec netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
IP-Config: Complete:
      device=eth0, addr=10.10.10.1, mask=255.255.255.0, gw=10.10.10.254,
     host=10.10.10.1, domain=, nis-domain=(none),
     bootserver=10.10.10.10, rootserver=10.10.10.10, rootpath=
yaffs: dev is 32505857 name is "mtdblock1"
yaffs: Attempting MTD mount on 31.1, "mtdblock1"
yaffs: MTD device does not support have the right page sizes
block 651 is bad ,so Try to clean!!
Clean block 651 Fail!!
block 944 is bad ,so Try to clean!!
Clean block 944 Fail!!
yaffs: Allocation block 384 was not highest sequence id: block seq = 5693, dev seq = 5694
yaffs tragedy: attempting to use non-directory as a directory in scan. Put in lost+found.
VFS: Mounted root (yaffs2 filesystem).
Freeing init memory: 308K
init started:  BusyBox v1.01 (2006.02.06-07:50+0000) multi-call binary
Starting pid 17, console /dev/console: '/etc/rc'
Bummer, could not run '/etc/rc': Exec format error
Starting pid 22, console /dev/console: '/sbin/getty'
Документации ровным счетом никакой с атс не предоставили
Проблема, по моему мнению в нанд памяти. В связи с чем вопросы:
Как прошивается данное устройство? можно ли полностью очистить нанд память.
Если не составит труда участникам, то не откажусь от мануала по прошивке и программ.)) и самой прошивки.
Очень жду ответа.
Заранее благодарен
 Заголовок сообщения: Re: ipecs-mg 100
Непрочитанное сообщениеДобавлено: 11 апр 2017, 09:43
Я бы посоветовал процедуру рекавери. При рекавери тестируется память и исключаются битые сектора.
Используется специальная прошивка recavery.
За это сообщение автора Dron поблагодарил: kryuchkov
Непрочитанное сообщениеДобавлено: 11 апр 2017, 09:49
Не могли бы вы, если это возможно предоставить инструкцию?
Непрочитанное сообщениеДобавлено: 11 апр 2017, 09:52
https://yadi.sk/d/ppJn2HJgqyxtR
Непрочитанное сообщениеДобавлено: 11 апр 2017, 09:54
Премного благодарен, буду разбираться.
Непрочитанное сообщениеДобавлено: 11 апр 2017, 11:07
Уточните в каком положении должны находится переключатели MODE? on или off?
Непрочитанное сообщениеДобавлено: 11 апр 2017, 11:15
Я думал, вы уже все сделали!
Где-нибудь в инструкции по процедуре рекавери вы видели что-нибудь про эти переключатели? Там этого нет, значит, и трогать их не надо!
Непрочитанное сообщениеДобавлено: 12 апр 2017, 11:56
Все получилось вчера, при запуске все же мелькают сообщения о битых блоках памяти, но атс стартует корректно. Спасибо за помощь.
