Текущее время: 25 апр 2024, 00:14
 Заголовок сообщения: Re: емж800 связь с другими атс-ками.
Непрочитанное сообщениеДобавлено: 19 янв 2017, 16:57
Вот, что показывает астерикс при звонке.
Код:
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] chan_ooh323.c: ++++  ooh323_indicate 22 on ooh323c_28 is -1
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] chan_ooh323.c: ----- ooh323_indicate 33 on call ooh323c_28
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] chan_ooh323.c: ++++  ooh323_indicate 33 on ooh323c_28 is -1
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] app_dial.c:     -- SIP/4301-00000153 is ringing
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] chan_ooh323.c: ----- ooh323_indicate 3 on call ooh323c_28
[2017-01-19 17:53:03] VERBOSE[25802][C-000000e4] chan_ooh323.c: ++++  ooh323_indicate 3 on ooh323c_28 is -1
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: ---   ooh323_update_writeformat ulaw/20
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: ---   find_call
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: +++   find_call
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: Writeformat before update slin/(alaw)
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: +++   ooh323_update_writeformat
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: ---   setup_rtp_connection 172.19.2.8:20512
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: +++   setup_rtp_connection
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: ---   close_rtp_connection
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: +++   close_rtp_connection
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: ---   onCallCleared ooh323c_28
[2017-01-19 17:53:05] VERBOSE[25801] chan_ooh323.c: +++   onCallCleared
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] app_macro.c:   == Spawn extension (macro-dial-one, s, 43) exited non-zero on 'OOH323/172.19.2.8-48' in macro 'dial-one'
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] app_macro.c:   == Spawn extension (macro-exten-vm, s, 7) exited non-zero on 'OOH323/172.19.2.8-48' in macro 'exten-vm'
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] pbx.c:   == Spawn extension (from-internal, 4301, 2) exited non-zero on 'OOH323/172.19.2.8-48'
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] pbx.c:     -- Executing [h@from-internal:1] Hangup("OOH323/172.19.2.8-48", "") in new stack
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] pbx.c:   == Spawn extension (from-internal, h, 1) exited non-zero on 'OOH323/172.19.2.8-48'
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] chan_ooh323.c: ---   ooh323_hangup
[2017-01-19 17:53:05] VERBOSE[25802][C-000000e4] chan_ooh323.c: +++   ooh323_hangup
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c: ---   ooh323_destroy
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c:  Destroying 172.19.2.8
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c:  Destroying ooh323c_28
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c: ---   find_user: (null), 172.19.2.8
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c: +++   find_user
[2017-01-19 17:53:06] VERBOSE[16656] chan_ooh323.c: +++   ooh323_destroy
Непрочитанное сообщениеДобавлено: 19 янв 2017, 17:15
А по поводу связи с сочи и односторонней слышимости. Нашел похожую тему http://komendant.pro/support/index.php/ ... ead/88720/
но не понятно, в итоге помогло это или нет.
У себя на сочинской атс пробовал ставить, разницы не заметил.
Непрочитанное сообщениеДобавлено: 20 янв 2017, 10:36
так спроси его в "личке"...
Непрочитанное сообщениеДобавлено: 20 янв 2017, 10:48
Написал. Ответа пока нет
Там просто участвовал ув.Дрон думал он может знает чем закончилось
Непрочитанное сообщениеДобавлено: 20 янв 2017, 10:55
Так там речь об налоговых внешних линиях. И закончиться должно было хорошо... :-)
Rambler Top100
